Load the items you want to soak into the washer drum.
Press the "Power" button to turn on the washer.
Press the "Pre Wash" button, this will start a pre-wash cycle that will last for 5 minutes, this will give you the time to add any detergent or laundry pre-treatment solution.
Press the "Start/Pause" button to start the pre-wash cycle.
Press the "Delay Start" button to set the time you want the washer to start the main cycle. This will give you the opportunity to soak the clothes overnight
Press the "Start/Pause" button again to start the main cycle after the pre-wash cycle is complete.
Leave the items in the washer overnight.
In the morning, press the "Start/Pause" button to start the main cycle again.
When the cycle is complete, unload the items from the washer and dry them as usual.
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
Hi! If the pre-wash light flashes it means you are not getting enough water in the machine, check the pressure chamber, pressure switch, fill hoses and valves. For a workshop manual on the WMA50 which includes fault finding, visit www.selfix-uk.co.uk
To Set the Cycle Completion Signal Tone Level • With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator Lights flashing. • Press the "Tone Level. • As you press the "Indicator Lights illuminating and the Cycle Completion Signal Tone level changing. o If none of the Wash Cycle Indicator Lights are illuminated, there will be no tone. The Cycle Completion Signal is turned off. o If one of the Wash Cycle Indicator Lights are illuminated, there will be a low Cycle Completion Signal Tone Level. o If two of the Wash Cycle Indicator Lights are illuminated, there will be a medium Cycle Completion Signal Tone Level. o If three of the Wash Cycle Indicator Lights are illuminated, you will be at the maximum Cycle Completion Signal Tone Level. • Press "START" to save your settings.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
