Check that your pressure tube is plugged into the control board. Take the back cover to control board off, pressure tube comes up from tub and should be plugged into the control board.
Try to clean the discharge pump filter first (Instructions in the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out this posting:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Hello &
Welcome to FixYa
This problem
is caused when the motor goes bad and needs replacement. The control will fill
water and then sends signal to the motor to start a cycle, if it won't work
then it will drain the water and so won't start the cycle. However, it can also
be a bad door latch-lock assembly as if the control senses that the door is not
closed it won't start the cycle. If you hear any humming buzzing sound from the
bottom of the unit then replace the motor if not then replace the latch
assembly. Please get back to me if you have any other questions.
Kevin
