To run an outlet you need a neutral, which is not present. I would advise contacting an electrician.
Glen,
I would advise contacting an electrician, working with electricity can be dangerous to you and your property and could even result in death. With that said, what really needs to be done here is a 3 wire cable with ground (12 gauge or 14 gauge, depending on what the circuit is wired in) needs to be run from the light to the switch. This way you would bring power down on the black, bring ground down on the bare, bring neutral down on the white, and switch the light with the red. Then you would have a proper neutral to connect to the neutral screw on the outlet.
