SOURCE: Pictures
Navigate to the site with the pic's you want, hold down the stylus on the image, and select "Save.."
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
