Ovens Logo
Posted on Feb 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the temp from Celsius to Fahrenheit? Whirlpool Gold.
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Feb 27, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524228
Points
8345
Press (precise)clean for 5 seconds, display shows temp Celsius press it again for 5 secs display shows temp Fahrenheit, press off/cancel to store
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
How do you know your kitchen aid subra oven is in Farenheit or celcius
Open the door and hold the broil button down for 10 second. This should change it.
To Change ?C to ?F: Press OPTIONS, then 1 on the keypad for Fahrenheit. To convert back to Celsius , press OPTIONS, then 1 again on the keypad.Nov. 23, 2017
How can I change my Kitchen Aid oven from Celsius to ...
Videos as well
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02YWcSfb2hUParUFl8YF9TOwoZaww:1625011130279&q=kitchenaid+subra+oven+change+fahrenheit+or+celsius
Jun 29, 2021 • Ovens
1helpful
4answers
Cant figure out how to get back to farenheit temp..
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide http://www.ajmadison.com/ajmadison/itemdocs/8300609.pdf
2answers
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
How to change from Celsius to Fahrenheit
100C = 212F
https://www.google.co.uk/search?q=oven+temperature+chart+printable&espv=2&tbm=isch&tbo=u&source=univ&sa=X&ei=P1YAVcvDA4rkaIrSgXA&ved=0CC4QsAQ&biw=1920&bih=925
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
2helpful
Change oven from celsius to fahrenheit
press the custom broil button for about 5 seconds, or possibly the bake button depending on the model
31helpful
3answers
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 • Ovens
3helpful
Changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
