No center channel sound.....I've tried everything. I even tried different speakers, wires etc. To simplify I just hooked up antenna for fm and just center speaker and put it in "5 channel stereo" mode and nothing...If I move center channel to right front, it works.
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Probably bad antenna wire at the antenna itself. Try plugging a piece of bare wire into the antenna hole (the 1/8" hole in the center) on radio, you should get something, hissing or some sound.
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Terrible problem. I know what your going though. Route your AM/FM Antenna wire, and Speaker wires separate from the CD Antenna cable and power supply wires. If you can, twist the speaker wires. If the Speaker wires are run along side the CB Antenna wire for a short distance, you will pickup feedback. If you much have the Antenna wire get near the speaker wires, have the antenna wire cross the speaker wire at a 90 degree angle. Try not to run the antenna wire in paralell with the speaker wires. Good luck
