SOURCE: number lock won't turn on
When enabled, this allows the user to type numbers by pressing the keys on the number pad, rather than having them act as up, down, left, right, page up, end, and so forth.
in bios is where you can set number lock to enable at start up
so restart and enter set up(bios) and change it to lock numbers at start up
if you need more help just let me know
electech
SOURCE: my laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
SOURCE: num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
SOURCE: FIXED keyboard stuck in fn mode ASUS 1000h eee
thats a good one for people with long fingers!
