If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
