SOURCE: Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
SOURCE: Tv wont come on
i think it's the built-in power surge/failure sensor. Plug the TV into the wall and press RESET on the remote twice.
SOURCE: RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
