Which way does they combo work and how many rotations on each number. Does it open on the last number or do you have to turn it back until it opens
Go to honeywellsafes.com apparently brinks was bought out
I Have A brinks security safe with a three(3) digit combo to open the problem is I forgot the 3 digit no# to open
You need to fax a notarized letter stating that you are the owner of the safe, fax to first alert/honeywell. You need serial & key no. They called me with the combo within 24 hrs, nice helpful people at First Alert. Then I followed solution #2, hooray!
Try this...
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
I have a brinks home security safe model 5054 i have two keys and the combination directions have been trying to open will not open no matter how many times i try
go to www.firstalert.com they have the answer
Do I happen to still have the combination I have all my keys but I. Ink the combo got locked inside
I neeed a combinton nombor
Go to www.firstalert.com click on to combination and key request on the bottom right. print the form. Then fax or mail with a notary. Depending what you need, money is involved if it is the key you are needing. For the combo it is free. First Alert took over Brinks. Good luck!
What's the fax numberof first alert/honeywell?
Hello my name is lucia i have a brinks safe model 5054 i have the key but i lost the combination what can i do to re open the safe?
I found a solution to send your model #, serial # and key # to Sisco at 2835 E. Santa Ana St, Compton, CA 90221. I faxed mine to 310-638-3489. I have not heard back yet.
ENE CB714 Cardbus/MediaReader Controller.i want the update
lost combo cant open
hello my name is lucia i have a brinks safe model 5054 i have the key but i lost the combination what can i do to re open the safe?
I lost the combination to my model 5054 safe .Could you sent me the combination? Thanks!
i lost my code to get into my safe what can i do
I have a Brinkssafe and it is oppen and I have the key, just can"t find the combination. Please help
help caan't get my saafe open. i have the 5059 safe. we have key but no combination
I have the same problem with the Brinks safe. I have the key but can't remember the combination to the lock. Can you help
yes i have a brinks safe model 5054 i have the key and no combo! PLEASE HELP!!!!!!!!!!!
I have a Brinks combination safe, model 5054. I have the combination and it works fine but I would like to use the key entry option but have forgotten where to position the dial when I do that. Help?
halo my name is marcelino coronado i have brinks safe model 5054 i have the key but lost the combination please help
mY NAM IS jORGE GARCIA i HAVE A BRINK SAFE MODEL 5054, BUT i LOST THE COMBINATION, PLEASE HELP ME.
I alos have 5054D safe woth a key and do not know the combination. I recently bought it at an estate same. Please help.
