Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats the case you will need an Icom that will do UHF freqs.
