Hi, our LG Dishwasher LD 14AW2 is not turning on. Worked fine yesterday. This morning when went to turn it on at power button, nothing happened. We tried turning off at the power point and on again, but still nothing. Please Help? Honor
Most likley problem is the door is not closing properly or the door latch switch is faulty. This means the dishwasher controller is not getting the right signal before commencing the wash cycle.
Need to check the closure of the latch. If this is ok then replace the door switch.
View the door panel diagram, schematics and parts in this site http://spares.bigwarehouse.com.au/index.php?cPath=24759_25855_26296&sort=2a&page=1
First check the small electrical box at and behind the kick plate below the door. Possible loose connections, usually wire nuts make the connection, turn them clockwise to tighten, check for melted wires at the connection. If all ok test there with a voltage meter at the white and black wires. Should be around 110. If nothing house issue, if power dishwasher power button or eoc issue. You can reset the eoc by disconnecting power for 5 min then reconnect.
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
