Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
? 8:30 https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Good deal your machine is a Series 11. “”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.”” I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected? Are there any error codes to the LED display like dC or uC? If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code? Does the wash tub bang around in Spin Only cycle with the wet clothes load? Standing by for some feedback and I will try to help. Here is the Service Manual and parts look up.Can you let me know if you want to try to DIY the fix? FAV6800A/FAV9800A Service Manual for reference.Sears Parts Direct for reference. Rich
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
