Either the built on video card is not functioning properly or not activated in the bios. If you have a card that is fitted to an AGP slot it may not be seated properly. If you have a card fitted to an AGP slot and an expansion card placed in the first PCI expansion slot the problem is a conflict between the Video card and the card in that slot. Those two slots share resources. If you are using the built on card make sure it is activated in the Bios, assuming you can get that part to give you video. If you can't there may be a jumper on the board set incorrectly. As a final option, if everything appears to be working correctly it may be the monitor that is malfunctioning or a bent pin on the video cable.
