SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
You solved the problem yourself! This toilet is junk! I suggest replacing with something that works such as the Toto Drake.
SOURCE: Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
SOURCE: My saniflo toilet wont flush
You need a new capacator. The motor is trying to run but does not have enough electricty to get the motor up to full speed.
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
SOURCE: Push Button - Have to Hold Down Button
I had the same problem with mine and I lifted the tank lid off and
extended the rods they are threaded and turned them out a few turns and returned the lid back on and no more holding down the buttons
