Your VAIO® computer is not supplied with System or Application Recovery CDs. Use the VAIO Recovery Wizard utility to recover your computer's operating system and preinstalled software programs. For more information about the VAIO Recovery Wizard utility program: 1. Click Start from the Windows® taskbar, and then click Help and Support. 2. From the VAIO Help and Support Center, click VAIO Recovery Options. Your computer must have an active Internet connection to access the Sony online support Web site. Observe the proper safety precautions when you upgrade your Sony computer. See Before upgrading your computer.
3. Restore complete system menu. From the left menu of Vaio Recovery Center select "Restore complete system"
4. Start button.
5. Select "Restore C: drive" and hit Next.
6. Read the information on this new window, select "I understand" and hit Start.
7. "Are you sure?" If you made backup for all your data and really want to restore your Vaio as it was when you bought it you have to make sure that have it plugged in to a stable source of energy and press YES.
8. So ... next you should sit back and relax. Your computer will start showing the next messages
Shuting Down
Windows is loading files ...
Restoring your operating system
Please wait a moment while Windows prepares to start for the first time...
Windows Vista setup: The initial setup may take up to 15 minutes. Do not turn off the computer. Click OK to continue the setup process and wait until the "Set up Windows screen appears". Select OK
9. Take your time until your system install VAIO software
Finish to restart.
10. That's all. Now, your VAIO has the original operating system, drivers and software. Now you have to configure your VAIO as you want.
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
