This is a tricky problem, you need to troubleshoot this bit by bit - first take the memory out one stick at a time and try to turn it on each time, then try the hard drive. If it boots further with one of these things out then you know thats the problem. If it still doesnt boot after trying these components then you need a repair as it will be an onboard component.
My immediate guess would be the onboard power supply unit, unless your charger is broken and you can test with another charger to rule that out too.
