If you have tested the cord with a voltage meter, and are sure it is good, there are several other possibilities. The Kirby is designed so that it will not start unless the bag assembly and rug head ( or attachment hose ) are fully in place. Be sure the fiberglass housing at the bottom of the bag is tight against the side of the motor unit. If this is not the problem, your switch has probably failed and needs replacement. A less likely problem on a machine this new is that a carbon brush in the motor has either become badly worn, or is stuck in it's holder and will need replacement.
