Novatel Berlitz® Spanish Premier (727298403398) Full Version for PC, Mac Logo
Posted on Jan 12, 2018
Hi, I have the Berlitz Premium Spanish program. I have it installed at home on my PC (Windows 7 64 bit) and it works great. I installed it on my laptop (XP Professional 2002 SP3) and the Learning Centre does not display the pictures and it will not take any action. Can you help? Thanks, Ward Carson
Cannot install programs in windows 7
Here are a few things that instantly come to mind.
1. Make sure the application is Win 7 ready.
a. It is for 32 Bit or 64 Bit.
b. Use troubleshooting mode to install by right clicking setup.
2. Make sure you are an administrator. Admin rights!
3. All you really need is a good virus protection.
a. Try not to install too many troubleshooters.
2answers
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Hi sir im jeff and my question is that i cant scan my computer windows 7 prof using windows live essentials.
Hello
I am also using win 7 home premium.With microsoft security essentials.
There could be a few reasons why its not working for you.
1 If you have another anti virus program it must be completely un installed.
2 You downloaded win 7 32 bit, and not win 7 64 bit version.
3 Download corrupt.un install essentials and re download and install.
Hope this helps.
Thank for using Fix ya
1helpful
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
2answers
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Product key for offci 2007 home and student edition
hi, is your windows system still working and office 2007 still install in your computer? if yes, try download this program with name "ProduKey" this tool will list of MS program you install.
Top Novatel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
