Master
- Posted on Feb 26, 2011
Re: Washing machine Airturbo stops at 17 minutes and 7...
- Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
- The Water Drain error can be cleared by turning POWER SW OFF and back ON.
- If the water only trickles out of the draining hose, pause the
washer and blow air down the hose, you should hear the water inside the
unit bubble a few times. If you don't hear bubbles, the hose is still
blocked.
- Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until
the water runs clear from the drain hose.
- If the machine still fails to drain, you may need to replace your Drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
