Question about LG DU-42PX12XC 42 in. Plasma HDTV
Thick vertical red and blue line appears intermitantly
  • 10,421 Answers
T con problem with your TV.
Please get it repaired or replace the t con at dealer or tv repair shop.
Regards
Posted on Feb 26, 2011
SOURCE:
How do I fix red vertical line?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 22, 2015 | LG Televison & Video
My Sanyo tv has a white screen with blue and red vertical lines down it.
Thats usually caused by the T conn board which is replaceable www.tvrepairworld.com should be able to assist with the diagnosis and replacement parts.
Mar 02, 2012 | Sanyo Televison & Video
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Apr 03, 2010 | HP Officejet 4355 All-In-One InkJet...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Blue vertical line on LCD screen
Thus meaning what display on the LCD is exactly what "enters" through the lens. Is this a hairline or thick line appearing on the LCD and does the same happen on the photos/pictures when they are downloaded on a PC? If so "something" could have infiltrated into/onto the camera lens....
Jul 16, 2009 | Canon PowerShot SD890 IS Digital Camera
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
My sony FLASHES 4 times
( no vertical deflection Vstop IC 1509, Q1505)
http://www.iwaynet.net/~nesda/SonyBlink.html
Jan 02, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
LG DU-42PX12XC 42 in. Plasma HDTV Logo
89 people viewed this question
Ekse
