I attempt to take a picture with my camra and I get an error code each time. the batteries are brand new, set on auto (Does the same with all settings). The message I get is f 2.8 1/45 I dont have a manual that shows me the problem. Can you email me at [email protected] thank you for any help you can offer. Steve
SOURCE: samsung S630 junk
the beeping is the battery being dead but the black screen with random stuff sounds like the LCD panel is busted. i work at a repair shop and have the same problem with my samsung s630 major problem...lcd panel is not available anylonger for that model.
SOURCE: S630 camera not working !!!!!!!
If the camera was dropped, then it's really causing those kinds of issues.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Third, you could try cleaning the lens with a soft clean cloth.
Make sure you are wiping gently.
Fourth, try to take a picture using this way:
- Press and hold the shutter button halfway first for 3-5 seconds,
and then press it all the way down
Fifth, if it still does the same thing, then your camera needs to be repaired by a technician.
If you want to know where you could send it, just call the hotline of the manufacturer of your product so you could get assistance
about this matter.
SOURCE: samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
Turn off camera after the settings
have been changed to refresh the camera.
I am Judy Malone in Tenn and I had my camera all in box and ready to mail back to place listed on camera box. I had worked on camera for last few days and to no avail. I got the notice via email today and the usual steps that I've read before.
To take batteries out, insert again. And to hold the ON button to keep camera powered. Then press Center button OK and press RIGHT 3 times to Setup2...
Well, I could not get my camera to co-operate past the Press Right 3 times to setup 2. Only the usual screen with a few of the icons showing my battery had power. It would not do anything past this.
Well, I got mad...(smile) and figured something had to be wrong as it kept showing a 32 for picts and I knew I had taken 414 at least on my Lexar 512 MB (SD).
I thought something must not be aleigned properly..some pins inside or somthing, so I GENTLE tapped the camera against my kitchen table... First one side, then the other..and GUESS WHAT. My camera came to life and has been working fine since. I HOPE this is a permanent fix...as I love the camera and have said so.
So, for what it's worth...try this if everything else seems to fail...but please do it gently. And start from the beginning.
Take batteries out, then reinsert...and GOOD LUCK.
I will post again...and let you know if this continues to work.
I am amazed.
judy in Tenn
SOURCE: My brand new Samsung J845
I contacted Samsung Australia and was informed that this was a Water Sensor Level fault. The machine will be fixed under their warranty guidelines. Thank you.
