I have a enviracaire elite f300E. We ran out of propane, it worked fine for a few days. Now the furnace runs fine but it is not blowing air to heat our home. But you can clearly hear the machine working. The it lights but the blower isn't working.
Neon light on air cleaner does not come on 1. Make sure the furnace or air conditioner fan is running. 2. Make sure the access door is firmly closed. 3. Make sure the On-Off switch is in the On position. 4. On models without the Solid State Performance Indicator, if the electronic cell(s) are wet, check again in two to three hours.
1. Make sure the furnace or air conditioner blower is running. 2. Make sure the access door is firmly closed and latched. If door is not closed properly, an interlock keeps the air cleaner off.
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
there is a plastic cell key that keeps you from putting the cells in backwards. Simply reverse the cells and they should slide in fine.
I/O is the power switch, I think O is off.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
