1).try to replace the
battery.
2).remove MMC & try to switch on
mobile.
3).update h.set os from nokia care.
There might be a
software problem and some programs are not allowing you to start mobile ,so you can format the mobile so that you can have default settings for your mobile..........if that also doesn't solve your problem than go with flashing the
phone.both the process are described below
method 1 :*#7370# master reset (like
new phone)
method 2 :1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your phone will now be at its original factory settings.
Hope this help!!!! dont forget to rate this!!!
