Hey, Call your service provider to ask your Blackberry Network Unlock Code. when you change your current network provider you must need to unlock your Blackberry first. after unlocking you can use your Blackberry to any network.but network provider take time to give your imei unlock code.second option is, you can buy your Blackberry 8520 Unlock Code from third party . this is safe way to Unlock your Blackberry . they will charge little amount but they give your Blackberry Imei unlock code immediately. i hope this information is help you. Good Luck:)
It is very simple to unlock your Blackberry 8520 through Blackberry Mep Unlock Code. call your service provider . or buy your Blackberry 8520 Mep Code from third party. it is safe and trusted method to Unlock your Blackberry 8520.I hope this will help you :)Good Luck.
I know my solution to your problem is very late, but I just saw your post and it could be useful for your future mobile phones. I would recommend you to try Blackberry unlocking codes with IMEI for reliable, trusted, cost effective codes with good customer backup service.
Regards.
You can get unlock code from any mobile shop or websites which provide blackberry curve 8520 unlock code. Once you unlocked it with unlock code you can use it with any GSM network in the whole world. Through website you can get unlock code within few minutes from the comfort of your home & also at cheap rates compare with other ways (THAT IS GET UNLOCK CODE FROM A MOBILE SHOP). All you need to do is go to any website which offering the blackberry curve 8520 unlock code & order your unlock code by entering your imei number & network which your blackberry curve 8520 locked to. You`ll get your unlock code through e-mail with in you few minutes with instructions of entering the unlock code of blackberry curve 8520. That`s it your blackberry curve 8520 has unlocked & then you can use it with any GSM Sim card around the globe. This the best way among me to unlock your blackberry curve 8520.
Hi
u can get blackberry curve 8520 unlock code from this web http://gsmblackberryunlockcode.comthis is very good web I had also take code for my blackberryfrom this because it can provide u code also following instructionfor applying code on your mobile & also in cheapest price after this u will be able to use anysim card on your mobile & can use mobile in any country of the world
thanks
Hi
u can get blackberry curve 8520 code from this web http://blackberryimeiunlockcode.com
it can provide u code + following instruction for applying code on your mobile& also in cheapest price after this u will be able to use any sim card onyour phone
thanks
You can easily unlock your Blackberry cell phone,Simply enter unlock code through mobile keypad,You can get unlock code by BLACKBERRY CURVE 8520 UNLOCK CODE provider with Instructions.
THANKS ! ! !
To unlock your Blackberry curve 8520 you will need the unlocking code, to get the unlocking code for your blackberry device you can call *#06# and see the IMEI code, then go to some online unlocking website for blackberry like this one - unlock blackberry curve 8520 and order the unlock code using the IMEI and a carrier (it's very cheap) then read the instructions here - Blackberry curve 8520 unlocking instructions and unlock your blackberry!
SOURCE: i need unlock code for my blackberry 8520 curve
How To Unlock a Blackberry Curve 8520
1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
SOURCE: BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
SOURCE: locked out of my blackberry curve 8520 smartphone
Did you forget your own password? Don't worry you can use your PUK code to unlock blackberry curve 8520 password, just type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. After you put that puk code your blackberry unlocked from old password.
