Televison & Video Logo
Posted on Feb 25, 2011
(A replacement TV) TO: PROSCAN LCD TV I have cable Direct TV and hooked up your Mod #32LB30Q. All is well except that I can not adjust audio with the remote, only at the TV control. Hook up: Composite Input Video: L Audio: D, D1 - Your Spec's Component 2 : C, C1 does not work. Please advise, Thank You Paul Borba
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Feb 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
2210
Points
29
Need to program direct cable remote for new tv or use the new remote that came with tv for the audio.
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
3helpful
2answers
Is there anyway to hook up external speakers to the tv? Like a surround sound system? computer seakers?
there is no audio out in my proscan 32LB30Q tv so there is no way for me to hook it up on my amplifier....
In-adequate User's Manual
That connector passes through your full audio to a compatible receiver.
Unfortunately your SA-EX 310 does not have a coax digital input.
Most new receiver do so if you buy a new one you should be all set.
1helpful
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
2answers
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
None of the connections for my ps3 will work with my 32lb30q proscan 32 inch lcd flatscreen?
The product description says that your TV has 2 HDMI inputs. All you need is an HDMI cable to hook it up.
OR
It also says that it has the A/V inputs (red/white/yellow). Which you just plug in the cord that came with the PS3, each plug with the corresponding color. Good luck and thank you!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
