Most times you can just call the dealer and they can help you out.
Try this site
www.radio-code.com
4 thumbs up is greatly appreciated if you appreciate the reply. Thanks.
SOURCE: I have a 2004 Honda CRV and left the lights on and
Look inside your glove-box. There should be a small sticker, usually near the left front on the inside the glove-box door. There will be two sets of numbers. The number set with 5 digits is your radio code.
SOURCE: 2004 honda radio code
The dealer charges $60 for a duplicate key (with a chip in it). I wouldn't thing they would charge this for simply getting you the security coide to your readio.
The code normally comes on a separate document as does key codes or numbers. You could check the owner's manual to see if it was noted in there. (A bad idea.) Also check for a sticker inside your glove box. If that doesn't work then you need to remove the radio/CD player from the dash to get it's serial number from the back of it. Take that number with your VIN to a Honda dealer and they should be able to get your security code for you. They will likely ask for your driver's license & registration to prove you own the vehicle.
SOURCE: code for 2003 honda crv radio,need to reset radio
If you dnat have the owners manual (last pages), you will need contact your dealer, show the VIN number and request this code number; remember that this security code anyone could send you from internet (is a security code).
Sometimes you need to pay at dealer for this information.
I hope helps with this.
The dealer can provide that.
