Question about MTX T-Form04-05 Chevy Colorado Gray w/10'' sub Car Speaker
Which is the #2 cylinder on a 3.5L 5cyl chevy colorado?
  • 17,970 Answers
For Chevy Colorado...
Type: 3.5L I-5 (L52)
Firing order: 1 - 3 - 5 - 4 - 2
Hope helps (remember to rate this answer).
Posted on Feb 25, 2011
SOURCE:
How do I replace the intake manifold gasket on a 2005 chevy Colorado 3.5l 5cyl?
It's a big job that requires a good shop manual like alldatadiy.com. Spend a few bucks and do it right.
Feb 04, 2018 | Cars & Trucks
2005 chevy colorado 5cyl cranks won't start has new fuel pump later it started than it died
Make sure battery has a full charge and battery connections all good. The basic tests for, it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. Also check fuel injector pulse
Have you had the battery disconnected?
Oct 22, 2016 | Cars & Trucks
Can i run bosch platinum ir spark plugs in my 2006 chevy colorado 3.7l 5cyl?
you could.and they last a long time .i would use ac delco though.
Mar 15, 2015 | 2006 Chevrolet Colorado
2004 Chevy Colorado p0036
Change the 02 sensors and check for vacuum leak hoses evap , then disconnect battery and test again .
Jan 23, 2013 | 2004 Chevrolet Colorado
How much transmission fluid does my 2005 chevy colorado w/ a 3.5L 5cyl w/ an automatic trans take when removing the pan and replacing the filter.
start by adding four quarts, then start engine and put thru gears and then back to park and recheck and add as needed,just keep repeating process untill full,make sure you look on dip stick ,it will tell you what kind of transmission fluid to use.
Jan 21, 2010 | 2005 Chevrolet Colorado
Intake manifold cover
remove oil cap steam an it should just lift off
Feb 23, 2009 | 2005 Chevrolet Colorado
Vacuum leak
mine is doing the same, it's your pcv receptor on the manifold. that hard plastic cover is actually part of the intake itself, if it "came off" it would cut your intake in half. that seem seals the two halfs together. you gotta pull the whole intake off and replace it... or jimmy rig it.
Car Audio & Video Logo
5,722 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
