Sounds like you have too much running in the backround. Try uninstalling some of the programs you dont use. Even though you dont have the program open and being used, most programs start automatically and run in the backround to receive push notifications, etc. The 3g arrows thing is normal, its just indicative of if data is being sent or received (or both) at that particular moment in time.
SOURCE: droid eris won't play videos
Droid Eris Playback Digital Video Formats : H.264 , MPEG-4 , H.263 video and AMR audio , WMV (Windows Media Video)
So, ensure the videos you got from other phone are in right format for playing. If not, you could try this Daniusoft video converter to convert various video even HD videos(.MKV/.M2TS/.Tp) to Droid Eri-friendly format ...
Hope this helps
SOURCE: droid got wet can it be repaired...
Yes, take the battery and mem card out, get a big ziplock baggie, put it about half way full with white uncooked rice, put teh phone and battery in there and seal it up and DO NOT TOUCH FOR 5 DAYS!!!!
SOURCE: My droid screen suddenly turned
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
SOURCE: how do i unlock my
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
SOURCE: how to unlock a motorola
you can unlock it and switch over to another network , if you want to unlock, you can get codes here http://www.onlinegsmunlock.com/motorola-droid/rs7wp9/
you need to specify the country and network provider
