hi dear queen studio, youur D60 have the secuence motor damaged and need to be replaced the ( SQ base plate unit).Contact a Nikonservice station to do. Regards
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
Select Release Mode from the Quick Settings display and choose one of the two remote modes. The Quick-response remote mode fires the shutter as soon as you press the button on the remote. The Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
For full details, look at the "Releasing the Shutter" section in your manual (page 54 in my copy).
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
