SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
SOURCE: how do you replace the spool pin on a babylock
I am having the same problem with a Brother XR37!!! So frustrating. Were you able to remove the casing to replace the spool pin? If so, I would also love to know how!! Thanks :)
https://www.youtube.com/watch?v=c48K7tTm...
