Computers & Internet Logo
Posted on Jul 28, 2008
Connection problems with new Dlink Wireless G Router DIR-300
As I work through the installation, the program is coming up with Error 103 - internet connection not verified. I don't know whether it may have something to do with disabling the firewall (which I am not sure I have or how to disable). I have had a computer whiz try to set up the router to no avail, he thought it could have been the broadband modem that I have through Optus may not direct the internet through a secondary device to the PC but only directly. I checked this with Optus and apparently there shouldn't be a problem there.
  • 3 more comments
  • Anonymous Aug 14, 2008
    It worked fine for me on XP. The problem is when I'm trying to configure the router on Windows 2003 Server. I get the same error message but my internet connection is fine.
    Firewall is off.
  • abechudinich Aug 14, 2008
    When i have have hooked up everything, it starts to check my connection and then "error: 103 internet connection not verified" pops up
  • arjunbharaed Sep 07, 2008
    SAme Problem
  • Anonymous Sep 17, 2008
    same problem
  • Anonymous Oct 22, 2008
    Same problem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2012
Points
Check if you have installed Microsoft NET.framework 3.0 or 3.5.
if not install.
Then restart your computer and try again
also try to log to router by typing its IP. find place where your MAC address is and make clone.
2answers
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
2answers
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
2answers
I have windows xp the cd that came with dlink dir 300 want work on my computer so how can i install dlink?
to be able for you to understand the installation of your wireless router
go here : CLICK ME
complete installation,guide as well as some illustration are indicated
11helpful
3answers
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Error 103 - DLink DIR-300
Hi
please consider that the modem Software is just for first configuration for accessing the internet or configuring the wireless setup and change its password or other configurations.so normally you don't need to install that software if you have internet connection.
so if you want to configure or change its settings then try to access it from its built in website,
1-you changed the configuration before:
then for finding its website address try to look at "Default gateway" on your computer or your mobile wifi settings (this is your modem address. the address is the IP address and it is look like 192.168.1.1 (you can type "ipconfig /all" in windows command prompt or "ifconfig -l" in Linux based systems or goto your wifi settings on your mobile devices and see the "default gateway". then after finding the address try to type it on your Firefox,Chrome,Edge,internet explorer address bar)
2-you don't change it yet:
then normally its address is like 192.168.1.1 or 192.168.0.1 and mark it normally by the manufacturer on the bottom of you modem lable
after opening the website you should consider the default user name and password is (if you didn't change it before):
username:admin
password:admin
or
usermane:admin
password:1234
3answers
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
70helpful
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dlink DIR-300 wireless G router; browser freezes
when i login on it says pending so what do i do and the routersay that the net is hooked uo right
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Grand Canyon Tech
Grand Canyon Tech
