Question about Hotpoint Aquarius WF220 Front Load Washer
Programme settings WF20 - Hotpoint Aquarius WF220 Front Load Washer
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Won't let me put in seperate set points for cooling and heating. I reset to fac setting, it used to let me have 2 settings.
www.ask.com/mfg.name/make/model#/
/setup_procedures/
/program_instuctions/
/optional_settings/
/discription-of-settings/
/additional_settings/
by reviewing your information that you provided you state that the unit in a non-programmable unit, that means you have to use the pre-set options, they cannot be changed, only someone that is a programmer, if you want a programmable unit than you should buy one, because every time something goes wrong you have to re program the unit. good luck
Sep 17, 2015 | Robertshaw 9500 Digital Non-Programmable...
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
Why is my sanyo plv wf20 projector shutting down after I turn it on.
The fan may be out that keeps the bulb cool. The shutdown is to protect the lamp from overheating. Do you have any flashing indicator lights on the projector after turning it on?
-GWOOD
Jul 12, 2014 | Sanyo PLV-WF20 Projector
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
How do you get rid of the 3rd programme on the draytonLp 112 mk1 programmer
set the on and off times the same on programme two for example on time at 12 then off time at 12 this will in effect nullify programme Number two
Oct 16, 2012 | Heating & Cooling
Need to set time on 1500e lathem
Hello
To enter the programme setting mode, you should plug the AC adapter to AC outlet and remove the cover. Thereafter press 'Select' button once. The the clock goes into the programme mode showing "UP Arrow" on the display positioned at "Time"
Function of three control buttons.
'SELECT": You can select the desired programme setting modes by pressing "Select" buton. Selected programme setting mode is indicated by the "upward arrow" mark on the display.
"CHANGE": When you press "Change" button, you can increment the set value.
"SET": You can set the value selected on the display by pressing the "Set" button. Thereafter you press this 'Set" button again, you can return the clock to normal operation mode. OK.
Dec 14, 2011 | Audio Players & Recorders
I am trying to remove a program from my computer. I click on :set program access& default,then I click on change or remove programs,but i have the error code 5001 and set up DLL.cpp (439)
if you want to remove programm on your PC click on start locate control panel the click on hard and remove programm then locate the programm you want to remove and remove it. by clicking on the programm then follow the instruction. after removing in the control panel go the drive C locate programm file then locate the file of the programm you uninstall.
Mar 05, 2009 | Computers & Internet
Need help to change the programme settings
what kind of thermostat do you have
Nov 13, 2008 | Heating & Cooling
Hotpoint Aquarius WF220 Front Load Washer Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
