LG RHT397H DVD Recorder Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to set up and connect it to my tv and the tv channels just won't load.
Anonymous
Level 2:
New Friend:
  • Expert 119 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
119
Questions
0
Helped
32382
Points
369
Are you on Cable? Coax cable from wall to dvd player INPUT? Follow the setup menu to program channels.
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
1helpful
2answers
Game mode won't turn off
simply change the channel and it sets it back to TV mode
Never had an issue until yesterday... When I turn the tv on,it immediately begins scrolling through all the channels and won't stop. It will not respond to the
I will assume you tried to unplug the set and plug it back in.
If you are using a sat or cable box connected to the cable fitting on the set try connection from the AV jacks to one of the video inputs on the set.
If set does it via the rear jacks it is likely the box and not the set.
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
1helpful
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
