SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
