could be a blocked air vacuum line you should see a thin air line coming from the intake and go to the cam cover top check this line as they do block up after awhile and it will cause this problem. also if this is blocked you need to clean out the intake top as this is were it clogging up as well.
Try to point the transmitting IR diode on your remote at to the phone camera,if you see blinking when pressing butons , the remote is OK , if it didn't blink there is the problem
I had come home about a week ago and pushed the power button from my
remote but my tv did not respond. So I just went to the front panel and
pushed power but once the tv turned on, the volume was on full blast! I
used the front panel volume decrease to get the volume down, but when I
stopped pushing the button, the tv increased its volume to full blast
again by itself! Naturally I just turned the tv off for a few moments. I
tried the remote again, no response again, so I used the panel power
button. The tv volume was still full blast when it turned on but after I
decreased the volume it stayed this time. The picture is and has been
perfectly fine and the tv was working fine. The next day the problem
started all over and now once we turned it off from frustration of
having to manually use the panel to change channels, it now will not
turn on at all. I have changed batteries from my remote, reprogrammed my
remote, pushed system reset several times, unplugged it for a while,
bought a new surge charge, and even held the menu and device panel
buttons for 10 sec and tried to turn the t.v. on again! What other
options do I have or what may be the issue at hand and possible parts
that may need to be replaced?? Thanks!!
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
