Master
- Posted on Feb 25, 2011
Re: Base of faucet leaks- cannot remove set screw at...
If you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
