Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
  • Kingston Master
  • 27,725 Answers
Click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Posted on Feb 24, 2011
I have a kingston datatraveler 2 gb pen drive.it does not work properly.while insert it ,it shows"you need to format the drive: before use it" do you format it? while format it it shows the following satus: capacity:-191 MB, File System :-FAt ( Default), Allocation Unit in size:-4096 bytes and while start format : it gives a message : the drive is write protected: Why the capacity not showing 2 GB & how could I format it as well as use it properly?
Posted on Mar 17, 2011
2 Suggested Answers
SOURCE:
bronk50
  • 27725 Answers
SOURCE: can't remove write protection from
also
- Click permissions
hope this helps
Posted on Jul 15, 2011
How to remove write protection from kingston usb drive
From the Kingston website:
DT101G2 - DataTraveler 101 G2 FAQ
Is there any security or write protection feature available for this DataTraveler? Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective. Contact Kingston Technical Support for further assistance.
May 31, 2012 | Kingston DataTraveler 101 G2...
How to remove write protection from datatraveler 32gb
To remove write protection:
  • Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
  • Navigate to the following path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
  • Double click the key WriteProtect in the right pane and set the value to 0
  • In the Data Value Box, press OK button
  • Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
That is it, done. Goodluck
Jun 16, 2011 | Kingston Technologies 512MB DataTraveler I...
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
I am trying to format the 64 kingston DataTraveller usb but i cant because it is write protected
You will have to remove the write protection in order to be able to format the flash drive.To do so,
please follow the detailed instructions from the below page.
http://en.kioskea.net/faq/4214-remove-write-protection-on-pen-drive
Nov 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston datatraveler 512 MB is write protected. there is no switch.i cant format del data
Well u cannot do nothing than to kindly replace it. If u r able to get it working, it'll tell u same thing after sometime. 100%sure
Feb 07, 2010 | Kingston Technologies 512MB DataTraveler I...
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
REMOVE WRITE PROTECTED PENDRIVE
Should be a switch on the pendrive. Just push it in opposite side. That will disable the write protection.
Apr 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
3,795 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
