This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you SabiousOne
CAREFUL!!!! Go to a professional bike shop and let them see if you have enough stem (about 21/2" to 3") in the top tube. Less than that and it can snap off and you can get seriously hurt. More than likely, if they can raise it, you would only pay a minumum charge (not like a car, probably $5-$10)
It will be more if they have to install a new stem, because it involves taking it apart and putting it back together. But, it will be worth it if you like the bike other than it is not comfortable now. Remember, it is not made to be a cruiser which let you sit upright and are comfortable, Supension bikes are for mountain biking and rough terrain, going downhill and climbing. And you usually ride a smaller frame than normal because of how you ride the bike, too big and you lose control. So, the bars are almost always flat and you lean forward. I hope I answered your question, I have been in business for almost 40 years and do know what I am talking about.
you need a wrench big enough to go around the round nut like thing where the handle bars join the body of the bike. Undo this and pull the handle bars up or down. Make sure they are tight when doing it back up.
How do I adjust brakes on roadmaster mt sport sx
