I'm guessing this unit is an oven only. Is it new or have you ahd it for a while? New ovens often smell for a little while. Probably the best thing to do is to remove the oven from its cavity and sit it on a stool or the floor. Remove the outer casing from the rear and the top. This should give you a pretty good look inside. If it's a major problem you should spot it straight away. Good luck.
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
