Hello!
I
must inform you that most of the wireless headphones has an automatic
shut-off which puts it in stand-by when there is no sound going in to
it. Or if the sounds in your device is too quiet the headphones will think
you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as
well - assuming that your headphone base unit is connected to the
headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Go to the sound icon and right click and press Playback Devices, cick your headphones then properties then advanced and then turn up the sampling rate all the way 24 bit, 192000hz.
Also make sure your batteries are good and windows sound is turned all the way up and lower down on the physical headset.... this took me months to figure out!
