Question about Xact Communication Xact Portable Boom Box for XTR Receivers - XS075 Boombox
I have 2 Xact boombox with Xact XTR7 receiver sets - One I use at home & the other at work. The receiver at work recently stopped working. The Sirius logo comes on and the screen is illuminated but no sound and no ability to navigate through menu or anything. Took it home and popped it into my home boombox to see if the issue was the receiver or boombox, and same thing, so I decided to take my XTR7 receiver from home and use it at work until I got a replacement. Guess what? After one day of use, THAT one isn't working! Screen is illuminated, but nothing - not even the Sirius logo. I brought THAT one back home to it's original boombox and same thing. So obviously my work boombox has somehow fried both receivers. Tested my MP3 player on the boombox and it works fine. Just kills receivers I guess?!Has anyone ever heard of this happening? I'm pretty upset now considering I've had 2 receievers ruined within days of each other. I don't even know if they can be fixed or where to bring them. Please advise! Thanks!
3 Suggested Answers
SOURCE:
  • 124 Answers
SOURCE: boombox does not maintain connection to radio
if the problem can be "fixed" by pushing down the reciever, it must be caused by some sort of loose contacts or wiring. there's a good chance that tightning some screw will solve this problem. if you have basic electronic skills you can open the unit and check for any loose screw or wire.
Posted on Feb 15, 2006
SOURCE: I have a sirius ST-B2R boombox and want to play my ipod thru it
put batteries in it
Posted on Aug 18, 2011
My xact boombox just stops
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knifeyour radio will now play without holding it
Mar 26, 2013 | Xact Communication XS034 Boombox
Xact XTR2 will not turn on
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
Jun 17, 2012 | Sirius Satellite Radio XACT XTR2 Satellite...
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Mar 28, 2009 | Xact Communication XTR1 SIRIUS Radio...
Sirius Sportster SP-B1 Boombox
Your best best is to replace the units. Sirius usually does it for free for existing customers. You can a good discount on a new boombox as well. The new models are designed to work with more Sirus receivers on the market.
Dec 16, 2008 | Sirius Satellite Radio Sirius Sportster...
Xact stream jockey 11 sirius boombox xs034
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife your radio will now play without holding it
Aug 23, 2008 | Xact Communication XS034 Boombox
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
Powers on and off with batteries
i would say you have bad luck with boomboxes try getting an mp3 player. j/k
May 01, 2007 | Xact Communication Xact XS027 Portable...
Sirius problem
I have the same problem, when I contact Xact (through e-mail) they said that the unit would have to be replaced. They didn't say that THEY would replace it, but said it had to be replaced.
Mar 28, 2007 | Xact Communication XTR1 SIRIUS Radio...
Boombox does not maintain connection to radio
Here is the fix,Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife the radio will now play without any problem!
Dec 18, 2005 | Xact Communication XS034 Boombox
Xact Communication Xact Portable Boom Box for XTR Receivers - XS075 Boombox Logo
117 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
