SOURCE: blank dvd media is not reconized
1.Please cheack weather the DVD meadia is DVD R/W combo drive, 2.Then only the DVD media will be Burn or write tO the Blank dvd media & then check weather the blank cd is a dvd r/w cd.
SOURCE: LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful http://www.allformp3.com/dvd-copy-software/convert-vhs-to-dvd.htm
Please rate me solve if you like my solution.
Best regards,
Philip
SOURCE: LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
SOURCE: Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
