Holmes Products HLS1200-U 1 Gallon Humidifier Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2 of these humidifiers and neither seems to be dispensing moisture into the air. The fans work fine and the filters are new. I am using regular tap water and have placed them in a room and ran them for several hours without seeing any change in water level or moisture content in the air.......any suggestions.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103443
Points
14643
If your "tap water" is from a well, the humidifier may be clogged with mineral scale. Even if it is not well water, your municipal source may have a high mineral content.
Using a 50/50 solution of White Vinegar and water run through the system will usually clean the mineral scale out. In the future, I would recommend that you use Bottled Distilled Water. You can buy it by the gallon, inexpensively at grocery stores or pharmacies.
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 • Humidifiers
Hello...i have a sunbeam filter free warm mist humidifier,and i put the water in and turn it on but it doesn't seem to be working. All the lites are on but nothing and it's brand new too never been used.
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
HE220A1019 Whole House Humidifier
The humidifier is designed to "pull" the air through the water panel. After it does the humidified air will re-enter the plenum on the side of the opening that it is pulling in from. Just keep the water panel replaced every year and you will be fine.
Jan 26, 2009 • Humidifiers
11answers
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
2helpful
2answers
Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
2helpful
2answers
Only light moisture even at high setting
Link to Manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Filters can get dirty pretty quick with the use of tap water. I attached the manual for you so that you can clean it.
Personally, i replace my humidifier filter at least once every 2 months.
Good Luck.
No moisture
Is the level of water dropping? If so, the humidifier is working. If you have a cool air humidifier you won't see any steam or anything at all. You will just feel cool air. Watch the water level and see what happens.
Good Luck.
1helpful
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Top Holmes Products Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
