Hitachi 42HDS69 42 in. Plasma Television Logo
Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black screen for HDTV channels -- but TV menu and DVDs display normally
We've had our Hitachi 42" plasma for almost two years and it's worked great. But a few weeks ago, it stopped displaying over-the-air HDTV channels. It seems to think it's still displaying them--it shows the channel numbers when you flip through them via the remote, and it shows SD channels (and DVDs work/display fine). I checked the signal strength in the TV Menu -- all channels are 95% or higher strength. I got a new HD antenna, no change. I reset to factory settings, had the TV rescan for channels, etc. Obviously the display is working, but somehow it's not displaying the TV signals that it is receiving. Any suggestions?
thx Dave
  • 1 more comment
  • DTSch Aug 01, 2008
    Still looking for help. I've poked around in the onscreen menu and can't find anything that fixes it.
  • DTSch Aug 03, 2008
    Well, I feel dumb, but that fixed it. Thanks!
  • Anonymous Mar 26, 2014
    I can't get any channels on my bt vision, have tried scanning for channels , my aerial works but it says i have no signal strength, the night before there was thunder and lightning.
Anand Kumar
Level 3:
Genius:
  • Master 2,035 Answers
  • Posted on Aug 01, 2008
Anand Kumar
Master
Level 3:
Genius:
Answers
2035
Questions
Helped
852147
Points
5335
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Anonymous
Level 3:
  • Master 2,071 Answers
Anonymous
Master
Level 3:
Answers
2071
Questions
Helped
1015280
Points
5371
SERVICE MENU SETTINGS
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below.
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
panel
Displays panel resolution
power on time
Displays total working time of the set
backlight on time
Displays total backlight on time of the set.
calibration menu
By pressing “◄/►” buttons select the second icon. calibration menu appears on the screen.
color temp
By pressing /. button, select color temp. Press ./. button to set the color temperature. The
options are: 5500K, 6500K, 7500K, 9300K and user.
user color temp
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values.
  • Anonymous Aug 01, 2008
    Resetting the TV
    If the
    buttons on the remote AND the buttons on the TV case do not work (channels do
    not change and you cannot open or navigate the menu), the TV has stopped
    responding. Reset the TV as follows:
    NOTE:
    Some TVs have a reset
    button. If available and accessible, try using the reset buttons before
    using the steps below. Using the reset buttons can save time.
    1.
    Unplug the TV
    power cord from the power outlet.
    2.
    Unplug any
    connected devices (DVD, Set-top boxes, etc...)
    3.
    Press and hold
    the TV power button for five seconds.
    4.
    Plug the TV
    power cord back into the power outlet and turn on the TV.
    5.
    Open the
    on-screen menu to confirm that the TV is responding again.
    6.
    Turn off the TV
    and reconnect the devices.
    7.
    Turn on the TV.
I have some how changed the coloring on my hitachi tv and i cant get it back to normal?
go to the menue and look for picture prefences look for factury reset and hit it that might bring your factory settings back if it does not you might have a display problem
Replacement plasma screen
Should work fine, just remember not to force it when replacing. If your not sure how to do it, take it to a professional.
HD channels look terrible
You may not have the resolution set to hd even though you are on the channel. Confirm that you are using hd cable and your set is displaying 720p or greater. This will sometimes pop up on the screen when you tune to a hd channel. it sounds like you are on 480 i or p. good luck
4helpful
2answers
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
2helpful
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
16helpful
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
I have a plasma TV MAGNAVOX PHILIPS model-42MF7010/17
video processing is done on small signal board. If there is no on screen display ssb would the board to replace as micro processor generates the menu
2answers
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
