Televison & Video Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Magnavox 37MF23ID flat panel tv and the picture is black but I still have sound and can change channels. The tv is also making a somewhat high pitch noise while on. I have also had trouble with the tv recognizing the remote control so have to manually turn the tv off and on then manually adjust volume (I have a DVR so am able to change channels with the remote). Now that the picture is black and there is sound miraculously the remote function is working again. Any advice with either or both problems?
Anonymous
Level 3:
  • Master 675 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Answers
675
Questions
0
Helped
176324
Points
2146
The high pitched sound you are hearing is that of a failed power supply...it seems that the high voltage inverter for the backlight may be the cause of the no pix problem..this is a very common fault in these sets...there are filter capacitors that may have become leaky in this power supply circuit causing the noise you are hearing...as for the remote problem, I would have a tech fix the power problem first as this may also be causing the remote circuits in the tv to fail
Testimonial: "A great resolution! Thank you for the detailed feedback. Extremely helpful!"
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270561
Points
3723
Sounds like a power supply issue and a faulty backlight. This should be fairly easy to fix by a tv repair shop.
Testimonial: "Very helpful! Thank you very much!!"
Why does my TV on when the power button is off?
You need to spare yourself a lot of frustration and just replace the TV
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Television
Check to see in audio section of the menu if SAP (secondary audio program) is engaged---this will kill audio only on certain channels.
This feature is also used in many sat or cable boxes so you have to look there also.
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Magnavox 26 in lcd tv
May be that the back light is not working. could be the inverter board is bad or the back lights. both could be expensive to repair and parts hard to find since these sets com from China
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
