If you forget the security code, please try nokia master reset code : 12345. If it fails , just get the code by key in your IMEI number at :
www.nfader.su
or
www.nokialockcode.com/calculate.php
Regards, Jay
My nokia is not opening when I open it, it light up suddenly it will turn off. and there was written ''local mode''
SOURCE: Nokia 3120c-1c
hello sir, nokia 3120c-2c imei 353102027789418 please give me the restriction code:(((((
SOURCE: I forgot lock codes of
try entering 4 or 6 zeros or 1234 or 12345 or press zero until you have reached max entry it depends on the phone
SOURCE: forgot my security code
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: forgot security code
The IMEI is lock. You need to go to www.nokia-calculator.com, then pin you IMEI on the box dont forget to select the model of the phone then press calculate then once given the code key in the phone then it will be unlcok
SOURCE: how to unlock my nokia 3120c i forgot my security code
it is possible to do this only by the nokia care people....
