Cell Phones Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cell phone, model SGH-U600, does not ring. It does not ring for incoming calls (while screen is flashing), for incoming messages (screen display ok), and when I make calls, I cannot hear the dial tone nor the person answering the call... Everything else works fine! Is it possible to solve this problem?
Lebanon Raingam
Level 3:
  • Cell Phones Master 4,737 Answers
  • Posted on Feb 24, 2011
Lebanon Raingam
Cell Phones Master
Level 3:
Answers
4737
Questions
Helped
1385296
Points
16345
If it doesn't ring when there's incoming call even if the phone is not in silent/airplane mode, then the problem is with the Speaker, but if you can't even hear the dial tone and the other person speaking/answering, then there's another possibility. Your phone must have two speakers, one as a ringer and the other as ear-piece-speaker. The one you hear ringing and or when playing songs is the Ringer and the other you hear through when answering a call or the keypad sound is the ear-speaker. I would suggest you to check with a headset so as to find out whether there's internal circuit problem. If you can hear through the Headset, then replacing the speakers will fix your issue, but if you don't even hear from the headset, then the problem would be complicated and the repair will be more difficult.
With both issues, you'll need to visit a Samsung Care or a local Mobile repair shop to get it fixed. They will charge you for the replacement and for the service. But before that, you'd need to confirm what's the cause and if it's going to complicated and you are likely to spend much for the repair, I won't recommend getting it repaired. If cost of repairing is more or less than purchasing a new handset, then I hope you also won't opt for that.
Let me know if you need further help. But first try with the Headset.
Good Luck.
Thanks for using FixYa.
1helpful
No ringtone on incoming calls for Samsung sgh-u600
Try to press and hold the pound (#) button for 5 seconds to deactivate the phone's silent mode.
Unlock code samsung u600
Hi, You can get the unlock code for a Samsung U600 from www.unlock-zone.com/samsung-sgh-u600/rs5wp9/ at affordable cost.
STEPS FOR UNLOCKING SAMSUNG U600
Method 1:
1 - Switch ON your Samsung SGH-U600 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-U600 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-U600 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-U600.
3 - Compose : #0111*CODE#.
Display problem looks fuzzy
you contact samsung service center
Alerts give a single ring and do not display on screen.
To Do, Alarm and Incoming Messages give a single audio alert but to not display on the screen. The Snooze function does not work although it is selected. Missed calls do not display
2helpful
Locked in silent mode.
I had the same problem with my u600 until just recently. It's an easy fix:
Slide your phone open, then press and HOLD the "#" key until you see a message on the screen that says, "Exit Silent Mode". Voila! Your phone makes sound once again.
I hope this helped :)
Samsung u600 keeps freezing
Go for a format or flash to reinstall the factory operating software. this will fix it for you.
Rate this please.
1helpful
2answers
Samsung u600 restart problem
Ok try a full reset *2767*3855# make sure your phone is fully charged and dont remove the bad while in process wait for it to come back on.
2answers
My Samsung sgh u600 incoming calls go straight to voicemail
Check to see if you have any of the of the 'call diverting' features turned on...
Menu
7 (network)
Check call diverting and call barring are NOT active.
Samsung u600
Select Menu > Settings > sound settings > incoming call > ring tone (now press the i button at the center) and select Default Ringtones. You can select the ringtone here.
Please note, this is for the SGH-U600 model. If you have a different model, please post back with the correct model number.
If you find this solution useful, kindly rate this solution as "Fixya". Thanks.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
