Samsung HT-XQ100 Theater System Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the remote control type of Samsung HT-XQ100? Is there any universal remote that works?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2765997
Points
24828
My remote is bad and need to increase the volume manually on Samsung ht-txq120 home theatre system
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
I need the remote codes for a Samsung AH59-02291A
The Samsung AH59-02291A remote came with several Samsung Home Theater systems, including the HT-H4530 and the HT-H5500W. The remote is not a universal remote and will not control other devices. You can learn a bit more about the remote by looking at the manual for the home theater system that it came with. The HT-H5500W manual is available on that product support page: https://www.samsung.com/us/support/owners/product/2014-5-1-channel-blu-ray-home-theater-system-ht-h5500w. If you need a universal remote to control the home theater system, look for one manufactured and programmed after 2014 for the 2014 HT-H5500W.
I hope this helps.
5helpful
When I turn on the unit I get a symbol that is a circle with a diagonal line through it and then the unit turns off. Any ideas? (Samsung HT XQ100 Home Cinema)
Your fan is bad.
The system is intelligent. It knows it will overheat without a fan. It also knows there is a problem with the fan, so it throws its self into self-protect mode to keep from overheating.
Have a tech check your fan.
;o)
1helpful
2answers
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
1helpful
My device wont turn on (samsung HT-XQ100)
it mite from the overheating its happen to me
3helpful
Tengo un ht-xq100 pero esta bloqueado pues en el display aparece un circulo atravesado por una barra no accede a ninguna funcion y alos 15 segundos se apaga automaticamente
I have sumsung HT-XQ100 DVD player it is overheating even it is in cooled room .... I'm afrid to keep it running for long time ...
could you please helpe my ...
Regards,
2helpful
2answers
Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
