I want to change my phone time to military time but have been unable to do so. I have went to initial setup and tried to find the time and date option and wasn't able to find one. I have looked online and everyone has said to change the autoupdate option but there isn't an autoupdate option either. When I look in initial setup it says the following:
speaker phone
auto PIN dial
auto redial
display timeout
backlight
TTY setup
scroll
language
battery save
brightness
DTMF
hyphenation
master reset
master clear
But nothing about time and date and nothing about auto update. Please help!!!
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Ok - here's what you really do. Go to Settings - Initial Setup - Time and Date - then you have to change to 24hour by changing the am/pm toggle. Not the easiest thing to find.
I have blank screen can it be repaired on motorola raz3
All that is listed in initial setup I listed above. There isn't a time and date option.
Obviously nobody is actually reading my post, above I put in what all is under initial set up and there isn't a time and date option. I am asking if there is a different way to change the time or if there is another place to find the time and date option because as i stated above I do not presently have that option to choose from!
is there a way to change the time
settings and tools, world clock, select closest city, also Daylight Savins Time. Date and time will be autoset by tower.
